[mapguide-users] Mapguide Server / Worker process killer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jun 23 02:26:27 EDT 2008
Well...
According to the instructions, you should post here first.
The purpose is to keep duplicates and other unwanted items off the bug
tracker.
You should always search the bugtracker to see if someone else reported
the problem.
When the problem is that the server goes down, and the problem is
reproducible,
it is clearly a bug in the MapGuide server, and should be submitted to
the Trac, IMO.
Regards, Kenneth Skovhede, GEOGRAF A/S
Darrin Maidlow skrev:
> Thanks Kenneth,
> Is it appropriate to run things such as this one through the list
> first? Or just submit them to trac?
> Thanks
> darrin
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Sunday, June 22, 2008 4:18 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Mapguide Server / Worker process killer
> I don't know if Autodesk prefers that you submit bug reports directly
> to them,
> but for MGOS, the correct place to report errors is:
> http://trac.osgeo.org/mapguide/
> Since MGE/MGOS share codebase, I assume that it is easier to track the
> changes on the above url.
> Hi List,
> I've found a server killing item. I'm in the process of adding some
> layers to a runtime map object. As a result of bug on my end, I was
> able to take out the mapguide server. If you add a layer that
> references a layer group to a map, but forget to first add the layer
> group to the group collection, the mapguide server fails.
> My server is MGE 2009, running on windows 2003\ IIS6. I've replicated
> this using web tier on both 2003/IIS6 and Vista x64/IIS7
> Please let me know if this is the wrong place for reporting things
> like this.
> darrin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080623/0c30cbae/attachment.html
