[mapguide-users] Load balancing and RFC3
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jun 24 09:07:17 EDT 2008
I'm not sure it will work:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc42
"This RFC removes existing functionality. However, site and support
servers were difficult to configure and it is unlikely that this
functionality is currently in use. It will still be possible to turn off
unnecessary services by directly editing serverconfig.ini."
Regards, Kenneth Skovhede, GEOGRAF A/S
Gabriele Monfardini skrev:
> I've seen that in RFC3
> <http://trac.osgeo.org/mapguide/wiki/MapGuideRfc3> was proposed (and
> implemented in 1.2) to use a load balancing scheme that allows to have
> multiple site server under one web tier.
> In order to cope with sessions, each user should be served by the same
> server that fulfills his/her first request and at each new client the
> server is chosen in a round-robin fashion.
> Does everyone have tried this?
> I want to try this solution since the performances with 1 server are
> quite poor (several seconds to zoom or pan in map with a few Postgis
> layers), and moreover, CPU usage  goes near to 100% for 3-4 seconds at
> each request. I think that with one server service time would be quite
> long if there are several request together.
> I've tried with version 1.2 and it doesn't work properly. Requests
> from different clients are correctly dispatched to my two servers but
> the server that is not in the same machine of the web tier keeps
> telling that the session is expired or non valid.
> I've configured webconfig.ini as in RFC3.
> Am I missing something?
> Gabriele
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
