[mapguide-users] Load balancing and RFC3
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 24 09:29:49 EDT 2008
Are you using tiled maps?
On Tue, Jun 24, 2008 at 10:58 PM, Gabriele Monfardini
<gabrimonfa at gmail.com> wrote:
> I've seen that in RFC3
> <http://trac.osgeo.org/mapguide/wiki/MapGuideRfc3> was proposed (and
> implemented in 1.2) to use a load balancing scheme that allows to have
> multiple site server under one web tier.
> In order to cope with sessions, each user should be served by the same
> server that fulfills his/her first request and at each new client the
> server is chosen in a round-robin fashion.
> Does everyone have tried this?
> I want to try this solution since the performances with 1 server are
> quite poor (several seconds to zoom or pan in map with a few Postgis
> layers), and moreover, CPU usage goes near to 100% for 3-4 seconds at
> each request. I think that with one server service time would be quite
> long if there are several request together.
> I've tried with version 1.2 and it doesn't work properly. Requests
> from different clients are correctly dispatched to my two servers but
> the server that is not in the same machine of the web tier keeps
> telling that the session is expired or non valid.
> I've configured webconfig.ini as in RFC3.
> Am I missing something?
> Gabriele
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
