[mapguide-users] Fusion tiled and dynamic layers same map
foolfish
xjimmyshcn at sohu.com
Tue Jun 24 09:54:42 EDT 2008
you can try cancel basegrouplayer. the basegrouplayer is No longer useful in
flexible weblayout.
Leandro R wrote:
> Hello list...
> I'm running MGOS 2.0.1 with bundled Apache. Windows Server 2003 R2.
> There is a map that works fine with PHPViewer but doesn't with Fusion.
> The Map has three BaseGroupLayer (TileCache) and many dynamic layers. One
> baseLayer come from WMS and the others (cached and dynamic) from ArcSDE
> 9.1.
> I've tested a map only with dynamic layers and worked fine; and the
> sheboygan tiled sample that has worked fine too.
> Does Fusion acept both tiled and dynamic layers in the same map?
> Is there any way to solved this?
> Thanks
> Leandro
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Fusion-tiled-and-dynamic-layers-same-map-tp17656321p18091550.html
