[mapguide-users] Fusion tiled and dynamic layers same map
Paul Spencer pagameba at gmail.com
Thu Jun 26 16:36:58 EDT 2008
It should probably work but I suspect that Fusion will only pick your
tiled layer OR your dynamic layers to display.  I think that we need
to look at the mixed tiles/dynamic stuff more carefully and make sure
it does the right thing.  Hopefully this will happen for the 1.1 release
Cheers
Paul
On 16-Jun-08, at 6:51 AM, Remigijus Brazys wrote:
> Any Answers?
> Best regards,
> Remigijus Brazys
> GIS analyst, InfoEra
> ______________________________________________
> Phone.: +370 5 2788456
> Fax.: +370 5 2784723
> Mobile.: +370 656 10089
> S.Zukausko str. 17
> LT-08234, Vilnius, Lithuania
> E-mail: remigijus at infoera.lt
> www.infoera.lt; www.gps.lt
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org
> ] On Behalf Of Leandro R
> Sent: Wednesday, June 04, 2008 11:50 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Fusion tiled and dynamic layers same map
> Hello list...
> I'm running MGOS 2.0.1 with bundled Apache. Windows Server 2003 R2.
> There is a map that works fine with PHPViewer but doesn't with Fusion.
> The Map has three BaseGroupLayer (TileCache) and many dynamic
> layers. One baseLayer come from WMS and the others (cached and
> dynamic) from ArcSDE 9.1.
> I've tested a map only with dynamic layers and worked fine; and the
> sheboygan tiled sample that has worked fine too.
> Does Fusion acept both tiled and dynamic layers in the same map?
> Is there any way to solved this?
> Thanks
> Leandro
> mapguide-users mailing list
