[mapguide-users] Fusion Anonymous Log In
Andy Morsell amorsell at spatialgis.com
Wed Jun 25 16:16:46 EDT 2008
Fusion will not accept the username and password parameters.  Your only
option is to create a session programmatically and pass it as a SESSION
parameter.  The concept is identical to the Sheboygan sample files.  Just
substitute the Fusion URL with the session tacked onto it in the frame src.
Or, you can use a Fusion template from the file system rather than one you
created in Autodesk MapGuide Studio.  In that case, it internally uses the
MGOS Anonymous user.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Shamrock
Shooter
Sent: Wednesday, June 25, 2008 12:49 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Fusion Anonymous Log In
Thank You Mr. Rock Beans.  Is there a way to pass the username=anonymous in
the fusion URL after ApplicationDefinition?  I can't get it to work.
I know in the old MOS 1.2 viewer you could add "&USERNAME=Anonymous" to the
end of the URL and it would automatically log in as anonymous.  But that
does not seem to work with the new Fusion Layout.
You have to pass the ?USERNAME=Anonymous&PASSWORD= through or better yet do
MapGuide API to create session and pass the session number. There are
examples of the API on the site in like 2-3 different languages.
The Rock
View this message in context:
http://www.nabble.com/Fusion-Anonymous-Log-In-tp18113838p18120396.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
