[mapguide-users] Programatically create MGP Packages or
dynamically load shape files
Rock Beans
rockbeans at gmail.com
Thu Jun 26 10:12:41 EDT 2008
You can always do a unmanaged shp file connection then drop shp files in to
this directory. From there you have to create layers and map additions
programmatically using the mapguide api in whatever web language you choose.
I have heard of some spped issues with unmanaged shps but it may be fixed
now.
The Rock
On Thu, Jun 26, 2008 at 7:21 AM, littlecharva <littlecharva at hotmail.com>
wrote:
> Hi,
> I'm starting to get my head around the way MapGuide works, and it seems
> that
> any maps I want to display have to live in a loaded Package - is that
> correct?
> I want to enable my application to accept Shapefiles uploaded by its users
> and display them. I can't find any information on loading Shapefiles
> directly into the MapGuide API, so is there a way to dynamically create
> Packages and load the Shapefiles into them?
> I'm not after a solution, just a point in the right direction.
> Cheers,
> Anthony
> http://www.nabble.com/Programatically-create-MGP-Packages-or-dynamically-load-shape-files-tp18132269p18132269.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080626/00400d74/attachment.html
