[mapguide-users] Cant view Maps, web pages
mrsyer
joes at mssurvey.com
Mon Jun 30 10:41:33 EDT 2008
hmm yes that is tricky. maybe ill try repairing it before unistalling open
source. Because i probably wont be able to package all my folders which
means hours of re-building. unless the folders and layers and data
connections will remain intact through an uninstall? i doubt it though.
anyways thanks for your help.
nclayton wrote:
> That's the tricky part. You'll need to reinstall from the mgos installer
> because the typical php install doesn't contain the mapguide php
> extentions.
> There may be a manual way to add them, but i have not done so personally.
> mrsyer wrote:
>> Ya thanks that makes perfect sense actually. I have been trying to get
>> dbconvert installed on my computer and i was messing around with some
>> things...
>> I will have to reinstall php because it is no longer on my computer. what
>> version should i be looking for?
>> nclayton wrote:
>>> If you're seeing that code in the page when you view it, then you either
>>> don't have PHP installed or it isn't properly configured in your web
>>> server software.
>>> mrsyer wrote:
>>>> Hi all, I cant view any of my maps or web pages wheter its local or
>>>> online. i can srill log into my site and see all my folders but I get
>>>> this when i try to view anything. be it in a browser or in studio.
>>>> thanks
>>>> and by the way... I also cant get into my Site Administrator browser
>>>> because I get a similar message.
>>>> <?php
>>>> // Copyright (C) 2004-2008 by Autodesk, Inc.
>>>> // This library is free software; you can redistribute it and/or
>>>> // modify it under the terms of version 2.1 of the GNU Lesser
>>>> // General Public License as published by the Free Software
>>>> Foundation.
>>>> // This library is distributed in the hope that it will be useful,
>>>> // but WITHOUT ANY WARRANTY; without even the implied warranty of
>>>> // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
>>>> // Lesser General Public License for more details.
>>>> // You should have received a copy of the GNU Lesser General Public
>>>> // License along with this library; if not, write to the Free Software
>>>> // Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
>>>> 02110-1301 USA
>>>> // Start output buffering
>>>> ob_start();
>>>> include 'mainframe.php';
>>>> BuildViewer(false);
>>>> // Set content length header
>>>> header("Content-Length:".ob_get_length());
>>>> // Flush output buffer
>>>> ob_end_flush();
View this message in context: http://www.nabble.com/Cant-view-Maps%2C-web-pages-tp18163532p18197183.html
