[mapguide-users] Cant view Maps, web pages
nclayton
nclayton at gmail.com
Mon Jun 30 10:55:30 EDT 2008
you may be able to copy the repository to a different location, reinstall,
then paste back. i'm not sure that this will actually work though, just a
thought.
mrsyer wrote:
> hmm yes that is tricky. maybe ill try repairing it before unistalling open
> source. Because i probably wont be able to package all my folders which
> means hours of re-building. unless the folders and layers and data
> connections will remain intact through an uninstall? i doubt it though.
> anyways thanks for your help.
> nclayton wrote:
>> That's the tricky part. You'll need to reinstall from the mgos installer
>> because the typical php install doesn't contain the mapguide php
>> extentions.
>> There may be a manual way to add them, but i have not done so personally.
>> mrsyer wrote:
>>> Ya thanks that makes perfect sense actually. I have been trying to get
>>> dbconvert installed on my computer and i was messing around with some
>>> things...
>>> I will have to reinstall php because it is no longer on my computer.
>>> what version should i be looking for?
>>> nclayton wrote:
>>>> If you're seeing that code in the page when you view it, then you
>>>> either don't have PHP installed or it isn't properly configured in your
>>>> web server software.
>>>> mrsyer wrote:
>>>>> Hi all, I cant view any of my maps or web pages wheter its local or
>>>>> online. i can srill log into my site and see all my folders but I get
>>>>> this when i try to view anything. be it in a browser or in studio.
>>>>> thanks
>>>>> and by the way... I also cant get into my Site Administrator browser
>>>>> because I get a similar message.
>>>>> <?php
>>>>> // Copyright (C) 2004-2008 by Autodesk, Inc.
>>>>> // This library is free software; you can redistribute it and/or
>>>>> // modify it under the terms of version 2.1 of the GNU Lesser
>>>>> // General Public License as published by the Free Software
>>>>> Foundation.
>>>>> // This library is distributed in the hope that it will be useful,
>>>>> // but WITHOUT ANY WARRANTY; without even the implied warranty of
>>>>> // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
>>>>> // Lesser General Public License for more details.
>>>>> // You should have received a copy of the GNU Lesser General Public
>>>>> // License along with this library; if not, write to the Free
>>>>> Software
>>>>> // Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
>>>>> 02110-1301 USA
>>>>> // Start output buffering
>>>>> ob_start();
>>>>> include 'mainframe.php';
>>>>> BuildViewer(false);
>>>>> // Set content length header
>>>>> header("Content-Length:".ob_get_length());
>>>>> // Flush output buffer
>>>>> ob_end_flush();
View this message in context: http://www.nabble.com/Cant-view-Maps%2C-web-pages-tp18163532p18197464.html
