[mapguide-users] Get Library path given sessionid?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sat Mar 1 06:25:50 EST 2008
Yes, it is possible.
When the viewer creates the runtime map, it places it in the root of the
session repository, and names it the same as the originating resource, ea:
Library://Folder/MyMap.MapDefinition
becomes the runtime map:
Session:xx-yy//MyMap.Map
You have to open the runtime map, (using MgMap.Open).
The resulting runtime map contains the original resource, in the
Property "MapDefinition".
Regards, Kenneth, GEOGRAF A/S
Andrew DeMerchant skrev:
> Is it possible to get the full library path to my map, given a
> sessionid? I'm playing around with the 'plot to dwf' example, and
> would like to have it pick a PrintLayout to use based on the library
> path of the map the user is printing. I just can't figure out how to
> work backwards like that - I had a look at the API's but didn't see
> any means to do this.....is it possible?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Skipped content of type multipart/related
