[mapguide-users] Get Library path given sessionid?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Mar 3 15:47:27 EST 2008
I don't suppose you can spell it out for me? PHP is not my forte and the
WebAPI docs for MGOS aren't exactly easy to navigate, in my books - I
can get around in PHP, but only by deconstructing existing things....an
example would help me out a lot.
Andrew
Kenneth, GEOGRAF A/S wrote:
> Yes, it is possible.
> When the viewer creates the runtime map, it places it in the root of
> the session repository, and names it the same as the originating
> resource, ea:
> Library://Folder/MyMap.MapDefinition
> becomes the runtime map:
> Session:xx-yy//MyMap.Map
> You have to open the runtime map, (using MgMap.Open).
> The resulting runtime map contains the original resource, in the
> Property "MapDefinition".
> Regards, Kenneth, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> Is it possible to get the full library path to my map, given a
>> sessionid? I'm playing around with the 'plot to dwf' example, and
>> would like to have it pick a PrintLayout to use based on the library
>> path of the map the user is printing. I just can't figure out how to
>> work backwards like that - I had a look at the API's but didn't see
>> any means to do this.....is it possible?
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
