[mapguide-users] Get Library path given sessionid?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Mar 5 03:41:38 EST 2008
I don't have an example at hand.
You can use the example from the "mapframe.php" file.
I have taken this from the "mapframe.aspx":
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection site = new MgSiteConnection();
site.Open(userInfo);
MgResourceService resourceSrvc =
(MgResourceService)site.CreateService(MgServiceType.ResourceService);
Next step, is getting the runtime map
MgMap map = new MgMap();
map.Open(resourceSrvc, mapName)
Next step is reading the Id:
string mapDef = map.MapDefinition;
I hope this helps you out. Both the sessionId and the mapName variable
must be passed on from somewhere.
Regards, Kenneth, GEOGRAF A/S
Andrew DeMerchant skrev:
> I don't suppose you can spell it out for me? PHP is not my forte and
> the WebAPI docs for MGOS aren't exactly easy to navigate, in my books
> - I can get around in PHP, but only by deconstructing existing
> things....an example would help me out a lot.
> Andrew
> Kenneth, GEOGRAF A/S wrote:
>> Yes, it is possible.
>> When the viewer creates the runtime map, it places it in the root of
>> the session repository, and names it the same as the originating
>> resource, ea:
>> Library://Folder/MyMap.MapDefinition
>> becomes the runtime map:
>> Session:xx-yy//MyMap.Map
>> You have to open the runtime map, (using MgMap.Open).
>> The resulting runtime map contains the original resource, in the
>> Property "MapDefinition".
>>> Is it possible to get the full library path to my map, given a
>>> sessionid? I'm playing around with the 'plot to dwf' example, and
>>> would like to have it pick a PrintLayout to use based on the library
>>> path of the map the user is printing. I just can't figure out how to
>>> work backwards like that - I had a look at the API's but didn't see
>>> any means to do this.....is it possible?
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
