[mapguide-users] Problems with mapagent in Mapguide OS
	version2	onubuntu?
    Andy Morsell
    amorsell at spatialgis.com
    Mon Mar  3 12:43:06 EST 2008
Here's what I get in Fiddler from Studio or from any mapagent operation from
the web tier tests:
HTTP/1.1 200 OK
Date: Mon, 03 Mar 2008 09:37:31 GMT
Server: Apache/2.2.4 (Unix) DAV/2 PHP/5.2.1
Last-Modified: Mon, 03 Mar 2008 00:11:21 GMT
ETag: "28f04d-49088f-3a461c40"
Accept-Ranges: bytes
Content-Length: 4786319
Content-Type: text/plain
ELF
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Monday, March 03, 2008 9:34 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Problems with mapagent in Mapguide OS version2
onubuntu?
When connecting with Studio, run a tool like Fiddler, in order to examine
the exact response you are getting from the server. Studio is probably
swallowing some exception.
Traian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Andy Morsell
> Sent: Monday, March 03, 2008 12:16 PM
> version 2 onubuntu?
> I just got to the same point on CentOS 5 and am seeing the exact same
> problems.  MapGuide Server starts successfully, PHP and Apache are
> working.
> The PHP test page shows MapGuide API support.  I was also able to
> login to mapadmin and  successfully load the Sheboygan package.  But,
> I cannot do anything involving the mapagent including any of the
> operations from the web tier tests and am prompted to download file
> type fcgi which looks to be ascii.  When trying to connect to the site
> via Autodesk MapGuide Studio 2009, I get an "unexpected error in
> contacting site URL" error.
> I concur that the problem looks like it is mapagent related and I am
> unsure where to start trouble-shooting.  The big question is did
> mapagent not build properly, or is there a configuration problem?
> Jo, out of curiosity, did you find the configure / make / make install
> to take an exorbitant amount of time?  I was finding that each step in
> my case was taking about 6 hours.  I also ran into make problems the
> first time through and ended up doing a build_oem.sh --clean and then
> restarting the process.  After that, the install seemed to complete.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jo Cook
> Sent: Monday, March 03, 2008 2:53 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Problems with mapagent in Mapguide OS version
> 2
> onubuntu?
> Hi,
> I resolved earlier problems by completely rebuilding my MGOS
> installation
> from scratch from the latest svn versions and it seemed to get all the
> way
> through without failing. I have even managed to get the server to run,
> which
> is a step forward. However, I am having problems with mapagent now, I
> think.
> What I can do:
> 1: Connect to mapadmin and load a package
> 2: Check the basic pages to ensure apache is working
> 3: Get to the mapagent pages
> What I can't do:
> 1: Connect using webstudio (times out) or mapguide studio (unexpected
> error
> contacting site URL), or fusion (times out displaying the sample data)
> 2: Use mapagent in any way. When I try and use any of the options like
> "Get
> Capabilities" I just get to download the mapagent.fcgi file, no xml
> document. The same thing happens when I try to use "Enumerate
> Reosources"
> from the URL as suggested in the documentation. If I try and open the
> fcgi
> file (in case it's actually an xml file but mis-named) it's
> gobbledegook.
> Neither the mgserver logs or apache logs appear to show anything wrong,
> but
> I assume this is a problem with mapagent not building or running
> properly.
> I'm not really sure how to find out though.
> Any thoughts?
> Jo
> http://www.nabble.com/Problems-with-mapagent-in-Mapguide-OS-version-2-
> on-ubu
> ntu--tp15799952s16610p15799952.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
