[mapguide-users] Problems with mapagent in Mapguide OS version
2 onubuntu?
Traian Stanev
traian.stanev at autodesk.com
Mon Mar 3 12:33:58 EST 2008
When connecting with Studio, run a tool like Fiddler, in order to examine the exact response you are getting from the server. Studio is probably swallowing some exception.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Andy Morsell
> Sent: Monday, March 03, 2008 12:16 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] Problems with mapagent in Mapguide OS
> version 2 onubuntu?
> I just got to the same point on CentOS 5 and am seeing the exact same
> problems. MapGuide Server starts successfully, PHP and Apache are
> working.
> The PHP test page shows MapGuide API support. I was also able to login
> to
> mapadmin and successfully load the Sheboygan package. But, I cannot
> do
> anything involving the mapagent including any of the operations from
> the web
> tier tests and am prompted to download file type fcgi which looks to be
> ascii. When trying to connect to the site via Autodesk MapGuide Studio
> 2009, I get an "unexpected error in contacting site URL" error.
> I concur that the problem looks like it is mapagent related and I am
> unsure
> where to start trouble-shooting. The big question is did mapagent not
> build
> properly, or is there a configuration problem?
> Jo, out of curiosity, did you find the configure / make / make install
> to
> take an exorbitant amount of time? I was finding that each step in my
> case
> was taking about 6 hours. I also ran into make problems the first time
> through and ended up doing a build_oem.sh --clean and then restarting
> the
> process. After that, the install seemed to complete.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jo Cook
> Sent: Monday, March 03, 2008 2:53 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Problems with mapagent in Mapguide OS version
> 2
> onubuntu?
> Hi,
> I resolved earlier problems by completely rebuilding my MGOS
> installation
> from scratch from the latest svn versions and it seemed to get all the
> way
> through without failing. I have even managed to get the server to run,
> which
> is a step forward. However, I am having problems with mapagent now, I
> think.
> What I can do:
> 1: Connect to mapadmin and load a package
> 2: Check the basic pages to ensure apache is working
> 3: Get to the mapagent pages
> What I can't do:
> 1: Connect using webstudio (times out) or mapguide studio (unexpected
> error
> contacting site URL), or fusion (times out displaying the sample data)
> 2: Use mapagent in any way. When I try and use any of the options like
> "Get
> Capabilities" I just get to download the mapagent.fcgi file, no xml
> document. The same thing happens when I try to use "Enumerate
> Reosources"
> from the URL as suggested in the documentation. If I try and open the
> fcgi
> file (in case it's actually an xml file but mis-named) it's
> gobbledegook.
> Neither the mgserver logs or apache logs appear to show anything wrong,
> but
> I assume this is a problem with mapagent not building or running
> properly.
> I'm not really sure how to find out though.
> Any thoughts?
> Jo
> http://www.nabble.com/Problems-with-mapagent-in-Mapguide-OS-version-2-
> on-ubu
> ntu--tp15799952s16610p15799952.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
