[mapguide-users] auto-computing map extents
Jackie Ng jackie.ng at aecsystems.com.au
Mon Mar 3 22:48:23 EST 2008
Hi All,
I am trying to bulk load a series of XML resources into MapGuide. Each
Feature Source that gets loaded references a distinct SDF file stored in an
externally aliased directory. All these SDF files share the same feature
schema and classes.
What I want to do is for each SDF file, is to load a series of templated xml
resources (feature sources, layers, maps, web layouts, etc) into a location
in the repository. I can process the feature sources and layers fine, but am
stuck with the maps, because I know that they __will__ have different map
extents.
Is there a way to automatically compute the visible map extents of a
particular group of feature sources?
- Jackie
View this message in context: http://www.nabble.com/auto-computing-map-extents-tp15819851s16610p15819851.html
