[mapguide-users] Initial Map-Load Time
    Bruce Dechant
    bruce.dechant at autodesk.com
    Thu Mar  6 13:31:32 EST 2008
Denis,
That is the only setting you need to change. What feature sources are you hitting? SDF? SHP?
Is it possible for you to cut-n-paste the contents of your serverconfig.ini file so that I can see all of your settings?
Thanks,
Bruce
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Denis Lalonde
Sent: Thursday, March 06, 2008 11:24 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Initial Map-Load Time
I've made the changes the the DataConnetionTimeout as shown by Bruce (and restarted the service & server) but I'm still having the initial delay after about 10 minutes of non-activity. Are there other settings to change?
Thanks,
Denis
----- Original Message ----
From: Bruce Dechant <bruce.dechant at autodesk.com>
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Tuesday, January 29, 2008 11:45:22 AM
Subject: RE: [mapguide-users] Initial Map-Load Time
The initial map loading delay is because none of the data needed  by the server is cached, ie: FDO connection, schema, class, spatial context information, etc...
Once the map has been loaded this information is cached by the server and makes returning it very quick for subsequent users.
The server eventually clears this cache after the information has not been used for a set period of time (default is about 10 minutes). You can adjust the amount of time before the server clears this information by changing the following parameters in the serverconfig.ini.
The following will set the FDO connection timeout to 1 day instead of the default of 10 minutes.
DataConnectionTimeout = 86400
Thanks,
Bruce
Sent: Tuesday, January 29, 2008 8:20 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Initial Map-Load Time
The first user of the day to "hit" my MG site (MGE 2008) always has to wait about 20 seconds for the initial map to load. Once the map is loaded, subsequent map actions take a very acceptable 2 seconds or even less. Also, other users who log onto the site at about the same time as user1 do not see this initial delay. If however, there is extended period of server inactivity, this initial map delay returns. (I assume once all session have expired)
Is there a way to avoid this initial map loading delay?
Never miss a thing. Make Yahoo your homepage.<http://us.rd.yahoo.com/evt=51438/*http:/www.yahoo.com/r/hs>
-----Inline Attachment Follows-----
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.<http://us.rd.yahoo.com/evt=51733/*http:/mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ%20>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080306/654df9c0/attachment.html
