[mapguide-users] Page Faults
BenoitBegin bbegin at geomapgis.ca
Thu Mar 6 16:37:44 EST 2008
I was wondering if there was anything special that needs to be done when
using Mapguide 1.2 with base layers and tiling? Under that setup, I
consistently get over 40 million page faults for the mgserver.exe process
over a 4 hour period of usage.
While a page fault might not be catastrophic, Mapguide is also painfully
slow. The machine running Mapguide has 2 Gigs of RAM and a dual core CPU.
There is no reason for Mapguide to generate so many page faults. Is there
anything in the Mapguide settings that needs to be set so that I can improve
its memory management perfomance and stop getting so many page faults?
In addition, I have developed a small application that pre-builds the
tilecache by just using the Rendering Service and getting the tiles at the
proper Row/Col index. This application has been running on our production
servers for the last 16 hours and the mgserver.exe is now at a huge 750
million Page Faults. The memory usage has also been steadily climbing and it
went from 75 megs to 200 megs over those 16 hours. The server has been doing
nothing but serve tiles. So I very likely leaked a little more than 100 megs
in 16 hours. That seems a bit excessive.
View this message in context: http://www.nabble.com/Page-Faults-tp15836139s16610p15836139.html
