[mapguide-users] Dynamically Modify SDF Source at runtime problem
Bob Cassarly
bob.cassarly at famis.com
Thu Mar 6 18:27:01 EST 2008
I am a MapGuide 6.5 Dynamic Authoring Toolkit developer trying to rewrite
some of my DAT code.
What I want to do is modify the source SDF of a layer from
FLOOR-01_Space.SDF to FLOOR-02_Space.SDF for the current session only (I do
not want to update the MapGuide repository). I know I am probably missing
something very simple but all I have not been able to find a way to do this.
The code included below does change the SDF source file BUT it updates the
MapGuide repository and this is something I definitely do not want to do.
Any help you could give me would be GREATLY appreciated!
<?php
require_once('../mapviewerphp/common.php');
require_once('../mapviewerphp/constants.php');
$mgSessionId = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST['SESSION']:
$_GET['SESSION'];
$mgMapName = ($_SERVER['REQUEST_METHOD'] == "POST")?$_POST['MAPNAME']:
$_GET['MAPNAME'];
try
// Initialize the Web Extensions and connect to the Server using
// the Web Extensions session identifier stored in PHP
// session state.
MgInitializeWebTier ($webconfigFilePath);
$userInfo = new MgUserInformation($mgSessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
$map = new MgMap();
$map->Open($resourceService, $mgMapName);
$layers = $map->GetLayers();
$layer = $layers->GetItem('Space');
$schemaClass = explode(':', $layer->GetFeatureClassName());
$fileName = 'FLOOR-02_Space';
$pathAlias = 'SDF_PATH';
//set the file name of the SDF file for the layer feature source
$resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
$byteReader = $resourceService->GetResourceContent($resId);
$doc = DOMDocument::loadXML($byteReader->ToString());
$node = $doc->getElementsByTagName('Value')->item(0);
$node->nodeValue = '%MG_DATA_PATH_ALIAS[' . $pathAlias . ']%/' . $fileName
. '.sdf';
$sdfDataDefinition = $doc->saveXML();
$byteSource = new MgByteSource($sdfDataDefinition,
strlen($sdfDataDefinition));
$byteSource->SetMimeType(MgMimeType::Xml);
$resourceService->SetResource($resId, $byteSource->GetReader(), null);
//set the feature name of the layer (usually the same as the SDF file
minus the file extension)
$layerDefResId = $layer->GetLayerDefinition();
$byteReader = $resourceService->GetResourceContent($layerDefResId);
$node = $doc->getElementsByTagName('FeatureName')->item(0);
$node->nodeValue = $schemaClass[0] . ':' . $fileName;
$sdfLayerDefinition = $doc->saveXML();
$byteSource = new MgByteSource($sdfLayerDefinition,
strlen($sdfLayerDefinition));
$resourceService->SetResource($layerDefResId, $byteSource->GetReader(),
null);
//save the map
//$map->Save($resourceService);
echo '<br/>Class0:' . $schemaClass[0] . 'X<br/>Class1:' . $schemaClass[1]
. '<br/>FSId:' . $layer->GetFeatureSourceId() . '<br/>FCName:' .
$layer->GetFeatureClassName();
catch (MgLayerNotFoundException $e)
echo '<p>Layer not found</p>';
catch (MgObjectNotFoundException $e)
catch (MgException $e)
echo 'error';
echo $e->GetMessage();
echo $e->GetDetails();
View this message in context: http://www.nabble.com/Dynamically-Modify-SDF-Source-at-runtime-problem-tp15885393s16610p15885393.html
