[mapguide-users] Linux Ubuntu 7.10 w MGOS 2.0
    Andy Morsell
    amorsell at spatialgis.com
    Tue Mar 11 12:15:04 EDT 2008
I did not encounter this problem when recently building MGOS 2.0 final on
CentOS 5.  I did the default build without Tomcat.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of larry white
Sent: Tuesday, March 11, 2008 5:50 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Linux Ubuntu 7.10 w MGOS 2.0
The MapGuide linux build process requires some manual intervention, because
of missing LD_LIBRARY_xxx references to lib_json in the CgiAgent
Makefile.am.
This has been a known error, for quite some time (Jason Birch reported this
at the end of November last year), but it has not been fixed yet.
I have no idea why this hasn't been addressed yet. (to be honest, its' a bit
annoying to have to adjust this on every build).
You can find the issue, and a patch here:
http://trac.osgeo.org/mapguide/ticket/347
This seems applies to any linux distro, as I have encountered it when
building on Ubuntu 7.10, CentOS 5, Fedora 7, and Debian Etch.
(btw, there can also be problems when building FDO Provider for Generic
RDBMS (ODBC and MySQL), in particular the UnitTest portion, because of
missing LD_LIBRARY reference to odbcinst. realize this belongs on the FDO
users list. I have also seen your recent postings to that list, so thought
i'd mention it here)
-- larry white
Sr Systems Analyst
neomatix.ca
Ed Davis wrote:
> Newbie Question:
> Have just completed building MGOS 2.O on Linux Ubuntu 7.10 using Quick
> Start for that Platform with the Tomcat option enabled.
> 1.       Seems to run, (more testing pending) but I have somehow either
> changed or deleted the Administrator/Admin combination from the
> MGServer login. Is there a table to reinstall or Edit?
> 2.       The build went quite well after excluding Oracle and ArcSDE in
> the FDO builds. I do however get the following  errors at the end of
> the make_mapguide.log
> Log Snippett.
> **Start of Errors************Line 2295
> /home/administrator/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandlerso:
> not found (try using -rpath or rpath-link
> 'Json::Value(bool)'
> ****More of the same****
> undefined reference to 'vtable for Json::FastWriter'
> collect2: ld returned 1 exit status
> make[3]: *** [mapagent] Error 1
> make[3]: Leaving directory '/home/administrator/mgsvn/Web/src/CgiAgent'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory '/home/administrator/mgsvn/Web/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory '/home/administrator/mgsvn/Web'
> make: *** [all-recursive] Error 1
> *****EOF********
> *Ed Davis, PMP
> <http://en.wikipedia.org/wiki/Project_Management_Professional>*
> *Manager, Solution Development Group*
> *AG Research Inc.*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
