[mapguide-users] Linux Ubuntu 7.10 w MGOS 2.0
larry white
larz at neomatix.ca
Tue Mar 11 13:31:18 EDT 2008
hmm. That's odd, because the changes found in the patch are not present
in the final release (I just checked again).
I have been making that change prior to building (has become kind of
automatic now).
Perhaps, the issue has been addressed in some other way?
I'll do a re-build on unmodified code, when i get a chance.
-- larry white
Sr. Systems Analyst
neomatix.ca
Andy Morsell wrote:
> I did not encounter this problem when recently building MGOS 2.0 final on
> CentOS 5. I did the default build without Tomcat.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of larry white
> Sent: Tuesday, March 11, 2008 5:50 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Linux Ubuntu 7.10 w MGOS 2.0
> The MapGuide linux build process requires some manual intervention, because
> of missing LD_LIBRARY_xxx references to lib_json in the CgiAgent
> Makefile.am.
> This has been a known error, for quite some time (Jason Birch reported this
> at the end of November last year), but it has not been fixed yet.
> I have no idea why this hasn't been addressed yet. (to be honest, its' a bit
> annoying to have to adjust this on every build).
> You can find the issue, and a patch here:
> http://trac.osgeo.org/mapguide/ticket/347
> This seems applies to any linux distro, as I have encountered it when
> building on Ubuntu 7.10, CentOS 5, Fedora 7, and Debian Etch.
> (btw, there can also be problems when building FDO Provider for Generic
> RDBMS (ODBC and MySQL), in particular the UnitTest portion, because of
> missing LD_LIBRARY reference to odbcinst. realize this belongs on the FDO
> users list. I have also seen your recent postings to that list, so thought
> i'd mention it here)
> -- larry white
> Sr Systems Analyst
> neomatix.ca
> Ed Davis wrote:
>> Newbie Question:
>> Have just completed building MGOS 2.O on Linux Ubuntu 7.10 using Quick
>> Start for that Platform with the Tomcat option enabled.
>> 1. Seems to run, (more testing pending) but I have somehow either
>> changed or deleted the Administrator/Admin combination from the
>> MGServer login. Is there a table to reinstall or Edit?
>> 2. The build went quite well after excluding Oracle and ArcSDE in
>> the FDO builds. I do however get the following errors at the end of
>> the make_mapguide.log
>> Log Snippett.
>> **Start of Errors************Line 2295
>> /home/administrator/mgsvn/Web/src/HttpHandler/.libs/libMgHttpHandlerso:
>> not found (try using -rpath or rpath-link
>> 'Json::Value(bool)'
>> ****More of the same****
>> undefined reference to 'vtable for Json::FastWriter'
>> collect2: ld returned 1 exit status
>> make[3]: *** [mapagent] Error 1
>> make[3]: Leaving directory '/home/administrator/mgsvn/Web/src/CgiAgent'
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory '/home/administrator/mgsvn/Web/src'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory '/home/administrator/mgsvn/Web'
>> make: *** [all-recursive] Error 1
>> *****EOF********
>> *Ed Davis, PMP
>> <http://en.wikipedia.org/wiki/Project_Management_Professional>*
>> *Manager, Solution Development Group*
>> *AG Research Inc.*
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
