[mapguide-users] Lable problem
Traian Stanev traian.stanev at autodesk.com
Fri Mar 14 14:50:08 EDT 2008
A good example for a custom function that takes a string and returns a string is ExpressionFunctionDecap.h/cpp, which is used for making strings lower case.
You can implement a similar function that runs a bidirectional reordering on the string. I recommend using PGBA for this. It is freely available at:
http://crl.nmsu.edu/~mleisher/ucdata.html
The basic premise - your custom function takes a string argument, runs PGBA on it and returns a reordered string. I guess you will need to be somewhat familiar with C++ to do all this.
I did start some work on this a while back, but have not had time to fully implement it. Using UCDATA would involve including a generated data file in the install, which would have taken more time than I had available. However, the general idea worked, I tested it with some Hebrew and Arabic strings.
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nimrod Cnaan
Sent: Friday, March 14, 2008 12:01 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Lable problem
Hello Traian,
you like your suggestion about implementing a reordering custom expression function, but not shore how to write one.
Can you lead me the & tell me where to start?
Nimrod Cnaan
Senior GIS Programmer
cell 972525355483
To: mapguide-users at lists.osgeo.org
Date: Mon, 10 Mar 2008 08:15:44 -0700
I think he means the text is appearing left-to-right, rather than the correct right-to-left. There is a ticket for that one (#271) and the solution is to implement a bidirectional reordering algorithm. I have such an algorithm, but so far have not had time to attempt to integrate it. Like someone else mentioned, there is a workaround, which involves storing the label strings in reverse in the data source.
Now that I think of it, it may be best to implement reordering as a custom expression function that one can use to reorder text. This way, no code changes would be needed apart from the implementation of that custom function.
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, March 10, 2008 10:51 AM
Does the font you are using exist on the server machine? If not the server will not be able to render it in the AJAX Viewer.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ????? ???
Sent: Sunday, March 09, 2008 3:48 AM
Subject: [mapguide-users] Lable problem
Im trying to set a hebrew lable for a layer, but in any font i try to set it in studio it does not show it corectly, can any one help me?
Express yourself instantly with MSN Messenger! MSN Messenger<http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080314/e8e5c334/attachment.html
