Re: [mapguide-users] It´s possible use google maps as base map in a MG application
    Zac Spitzer
    zac.spitzer at gmail.com
    Wed Mar 19 07:19:55 EDT 2008
you can use the trunk version of openlayers to use both mapguide and
google earth,
it has support for both map types. I think fusion can do the same
On Wed, Mar 19, 2008 at 10:11 PM, Jackie Ng <jackie.ng at aecsystems.com.au> wrote:
>  I do believe this would violate google's terms of service.
>  If you want to incorporate google imagery, you would have to do it the other
>  way round, with Google Maps/Earth as the "frontend" and MapGuide as the
>  "backend".
>  - Jackie
>  bigtower wrote:
>  > Hi,
>  > I need to use Tiled Maps from Google Maps as a base cartography in my MG
>  > application.
>  > The MG application is developed with MG 2008 Enterprise.
>  > If is necessary can use Fusion, I need to know if is possible use Google
>  > maps as other layer in my MG application.
>  > Thanks
>  View this message in context: http://www.nabble.com/It%C2%B4s-possible-use-google-maps-as-base-map-in-a-MG-application-tp16141337s16610p16142994.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
>  _______________________________________________
>  mapguide-users mailing list
>  mapguide-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
