Re: [mapguide-users] It´s possible use google maps as base map in a MG application
Paul Spencer pagameba at gmail.com
Wed Mar 19 07:41:26 EDT 2008
Jackie is correct, you have to be very careful of how you use Google.
OpenLayers incorporates Google (and Yahoo and Microsoft) mapping
services by using their APIs and thus does not violate their terms of
use technically, but you still need to make sure that your application
doesn't violate their terms of use.
There is quite a bit of documentation on using Google in OpenLayers in
the OpenLayers wiki and in the mailing list archives, I suggest that
you start there (http://www.openlayers.org).
It is technically possible to do the same in Fusion since we are
embedding OpenLayers as the mapping component, but it would not be
practical to do so at this time.  There is no API to make this happen
automatically yet, and the code to make it work from an application
developer's point of view would be convoluted.
Your best bet at this point in time is to start with OpenLayers
directly.
Cheers
Paul
On 19-Mar-08, at 7:19 AM, Zac Spitzer wrote:
> you can use the trunk version of openlayers to use both mapguide and
> google earth,
> it has support for both map types. I think fusion can do the same
> On Wed, Mar 19, 2008 at 10:11 PM, Jackie Ng <jackie.ng at aecsystems.com.au
> > wrote:
>> I do believe this would violate google's terms of service.
>> If you want to incorporate google imagery, you would have to do it
>> the other
>> way round, with Google Maps/Earth as the "frontend" and MapGuide as
>> the
>> "backend".
>> - Jackie
>> bigtower wrote:
>>> Hi,
>>> I need to use Tiled Maps from Google Maps as a base cartography in
>>> my MG
>>> application.
>>> The MG application is developed with MG 2008 Enterprise.
>>> If is necessary can use Fusion, I need to know if is possible use
>>> Google
>>> maps as other layer in my MG application.
>>> Thanks
>> View this message in context: http://www.nabble.com/It%C2%B4s-possible-use-google-maps-as-base-map-in-a-MG-application-tp16141337s16610p16142994.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
