[mapguide-users] DB XML Component Error in Dynamic Theming
Rahul unicorn_admirer at yahoo.com
Thu Mar 20 22:40:48 EDT 2008
Hi ,
      I checked the log file and posted the contents in my previous e-mail  but i have no idea how to debug this issue.
Error in the Map Server(MGOS 1.2.0)
Error: An exception occurred in DB XML component.
Error: XML Indexer:  Parse error in document at line, 61, char 12. Parser message:
Not enough elements to match content model
((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
Error in Apache Web Server
 [Tue Mar 18 14:43:37 2008] [error] [client 10.0.y.y] FastCGI: server
 "D:/Program Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe"
  stderr: PHP Fatal error:  Uncaught exception 'mgdbxmlexception' in
Unknown on line 0, referer: http://10.0.x.x:8008/mapguide/Officers/theme/thememain.php
Thks
Max
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Thursday, March 20, 2008 9:29:57 PM
Subject: Re: [mapguide-users] DB XML Component Error in Dynamic Theming
When that error comes, there is usually an entry in the error.log file, which indicates why the Xml was invalid.
This message will hopefully help you in locating the precise problem.
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
     I tried the 1.2 Viewer Samples but unable to get going and the same error -DB XML Component Error coming up in the application.In the same application i can perform theming on some sdf files and cannot perform on other files. On the other hand when i tried to do  theming in the MapGuide Studio 2008 , i can perform the same theming on the the layers with out any error.i am stuck and unable to move forward,how to resolve this Issue.
Thks
Max
To: mapguide-users at lists.osgeo.org
Sent: Wednesday, March 19, 2008 8:17:55 AM
If I recall:
1 - The Generic Tasks sample was built for MGOS 1.1.0
2 - I think there were schema changes to LayerDefinition in MGOS 1.2.0
Maybe try the 1.2 viewer samples, as are basically the updated version of
the Generic Tasks sample.
- Jackie
max_samart wrote:
> Hi ,
>      Thanks for your reply,i am using MGOS 1.2.0 ,yeh the exception shows
> that not enough elements to match content model , Anyway i will try to
> stylize the layer using the mapguide studio and  capture the xml output
> but what i use for the validation of the LayerDefinition document.
> Thks
> Max
> From: Jackie Ng <jackie.ng at aecsystems.com.au>
> Sent: Monday, March 17, 2008 10:25:43 PM
> It sounds like the layer definition xml does not validate. Are you able to
> capture the xml output of the theme layer and see if it is a valid
> LayerDefinition document?
> Also, what version of MapGuide are you using?
> - Jackie
> max_samart wrote:
>> Hi All,
>>          I have some sdf files as Polygons and when i want to use the
>> Dynamic Theming(GT Example), its use to give  mgdbxmlexception error,
>> although I can do dynamic theming on some other sdf layers in the map but
>> on some layers i am getting exception with pid terminated with exit
>> status'0' .Can anybody give some idea reagarding the same in order to
>> proceed further .
>> Thks
>> Max !!
>> ERROR IN THE MAPGUIDE SERVER
>> <2008-03-18T14:43:57>    Officer Error: An exception occurred in DB XML
>> component.
>> message:
>> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
>>  StackTrace:
>>  - MgResourceServiceHandler.ProcessOperation line 80 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>>  - MgOpSetResource.Execute line 109 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\OpSetResource.cpp
>>  - MgServerResourceService.SetResource line 728 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ServerResourceService.cpp
>>  - MgRepositoryManager.SetResource line 867 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\RepositoryManager.cpp
>>  - MgRepositoryManager.AddResource line 840 file
>>  - MgResourceContentManager.AddResource line 183 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>  - MgResourceContentManager.PutDocument line 624 file
>>  - MgResourceDefinitionManager.PutDocument line 554 file
>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>> message: Not enough elements to match content model :
>> ERROR in the WebServer-
>> [Tue Mar 18 14:43:20 2008] [warn] FastCGI: (dynamic) server "D:/Program
>> Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
>> (pid 4088) terminated with exit with status '0'
>> Unknown
>> on line 0, referer:
>> [Tue Mar 18 14:43:57 2008] [error] [client 10.0.z.z] FastCGI: server
>> Unknown
>> on line 0, referer:
>> ____________________________________________________________________________________
>> Never miss a thing.  Make Yahoo your home page.
>> http://www.yahoo.com/r/hs
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/DB-XML-Component-Error-in-Dynamic-Theming-tp16117523s16610p16118026.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
View this message in context: http://www.nabble.com/DB-XML-Component-Error-in-Dynamic-Theming-tp16117523s16610p16135228.html
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
-----Inline Attachment Follows-----
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080320/28548c12/attachment.html
