[mapguide-users] Ticket #462: Any workaround for the ticket ?
Ismael Cams
mapguide2007 at gmail.com
Tue Mar 25 09:31:11 EDT 2008
Until now I did not try this, but I will check if I get anything out of it.
Taking your answer in consideration I assume you also did not get around the
problem somehow ?
zspitzer wrote:
> did you try the CPL_DEBUG=ON option?
> I did and it didn't show anything from memory
> I was using a TIFF image from
> http://www.unearthedoutdoors.net/global_data/true_marble/download so
> it
> looks like the issue isn't gdal format specific.
> Zac
> On Tue, Mar 25, 2008 at 8:44 PM, Ismael Cams <mapguide2007 at gmail.com>
> wrote:
>> Hello,
>> is there any workaround available for the Ticket #462: Server Crash and
>> Unresponsive using OSGeo.Gdal FDO provider ?
>> I am encountering the same problem when trying to connect to MrSID
>> files. It
>> works fine for some time, but suddenly without any reason the server
>> crashes
>> or does not render anything at all. I already tried to convert the MrSID
>> format to tiff, but without any results. Is there some way to get around
>> this ?
>> View this message in context:
>> http://www.nabble.com/Ticket--462%3A-Any-workaround-for-the-ticket---tp16272293s16610p16272293.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/Ticket--462%3A-Any-workaround-for-the-ticket---tp16272293s16610p16274774.html
