[mapguide-users] Ticket #462: Any workaround for the ticket ?
Zac Spitzer zac.spitzer at gmail.com
Tue Mar 25 09:58:12 EDT 2008
unfortunately no..
On Wed, Mar 26, 2008 at 12:31 AM, Ismael Cams <mapguide2007 at gmail.com> wrote:
>  Until now I did not try this, but I will check if I get anything out of it.
>  Taking your answer in consideration I assume you also did not get around the
>  problem somehow ?
>  zspitzer wrote:
>  > did you try the CPL_DEBUG=ON option?
>  > I did and it didn't show anything from memory
>  > I was using a TIFF image from
>  > http://www.unearthedoutdoors.net/global_data/true_marble/download so
>  > it
>  > looks like the issue isn't gdal format specific.
>  > Zac
>  > On Tue, Mar 25, 2008 at 8:44 PM, Ismael Cams <mapguide2007 at gmail.com>
>  > wrote:
>  >>  Hello,
>  >>  is there any workaround available for the Ticket #462: Server Crash and
>  >>  Unresponsive using OSGeo.Gdal FDO provider ?
>  >>  I am encountering the same problem when trying to connect to MrSID
>  >> files. It
>  >>  works fine for some time, but suddenly without any reason the server
>  >> crashes
>  >>  or does not render anything at all. I already tried to convert the MrSID
>  >>  format to tiff, but without any results. Is there some way to get around
>  >>  this ?
>  >>  View this message in context:
>  >> http://www.nabble.com/Ticket--462%3A-Any-workaround-for-the-ticket---tp16272293s16610p16272293.html
>  >>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>  >>  _______________________________________________
>  >>  mapguide-users mailing list
>  >>  mapguide-users at lists.osgeo.org
>  >>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
>  > Zac Spitzer -
>  > http://zacster.blogspot.com (My Blog)
>  > +61 405 847 168
>  View this message in context: http://www.nabble.com/Ticket--462%3A-Any-workaround-for-the-ticket---tp16272293s16610p16274774.html
Zac Spitzer -
+61 405 847 168
