[mapguide-users] Selection problem in Fusion on MGOS2.0
Paul Spencer pagameba at gmail.com
Wed Mar 26 09:26:32 EDT 2008
This is a known issue and has been at least partially corrected in a
newer version of fusion which is not yet available.  I am not aware of
a work around with the current code except to fix the data not to have
NULLs (not an acceptable solution, obviously).
Cheers
Paul
On 26-Mar-08, at 2:07 AM, Katsuaki Soizumi wrote:
> Hi all,
> I have problem with selection in fusion.
> There are some cases that selection in build-in doesn't work for
> selecting features.
> It seems the features that have value for property as null cannot be
> selected.
> I looked up JavaScript of fusion and found below that an exception
> occurred.
> Value for PROPERTY_NAME property is null.
> Exception occurred in method MgProxyFeatureReader.GetProperty at
> line 448 in file d:\buildforgeprojects
> \mapguide_open_source_v2.0\build_23.8\mgdev
> \common\mapguidecommon\Services/ProxyFeatureReader.cpp
> I think something wrong on selecting processes when value for
> property is null.
> How would you figure it out?
> Thanks in advance.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
