[mapguide-users] Getting Started Site Admin Problem
Jackie Ng jackie.ng at aecsystems.com.au
Fri Mar 28 10:43:07 EDT 2008
You can start/stop mgserver using the Services Applet in Administrative
Tools. Or alternatively, you can run:
net stop "MapGuide Server v2.0"
net start "MapGuide Server v2.0"
Re: Trac tickets. I'm of the belief you should file tickets regardless of
how trivial they are. Worst case: it gets closed and forgotten, best case:
someone will actually look at it ;-)
- Jackie
Bob W wrote:
> It appears Christy’s idea about MapGuide service running was the problem
> in this case.  I don’t know how mgserver.exe is being started, but I see
> it running where it wasn’t before.  (I have a useful program free program,
> Process Explore, which shows the processes that are running.)  Is there a
> procedure to start and stop mgserver?
> With MapGuide running I can login to Site Administer.
> Should I still open a trac ticket?
> This solution has brought me to the next problem: loading the
> Sheboygan.mpg package.  I’ve downloaded Sheboygan.mpg, extracted the files
> and copied them into the C:\Program
> Files\MapGuideOpenSource\Server\Packages directory.  I can see the file in
> the directory via Explorer.  MapGuide Site Administrator – Manage Packages
> – Load Package displays a “No packages found.“ message, and no package
> names appear in the Configure Packages directory table.
> Suggested solutions would be appreciated.
> Bob W wrote:
>> When I get to the 4th step in the Getting Started instructions the
>> MapGuide
>> Site Administrator Login won’t accept the default user id “Administrator”
>> and password “admin”.  I get an “Authentication failed. Please enter a
>> valid
>> username and password.” message.
>> I’ve removed and reinstalled the application, but the problem persists.
>> Does anyone have a suggestion about how to get around this problem?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Getting-Started-Site-Admin-Problem-tp16308891s16610p16350327.html
