[mapguide-users] Getting Started Site Admin Problem
    Kenneth, GEOGRAF A/S
    ks at geograf.dk
    Fri Mar 28 09:46:14 EDT 2008
You can start/stop the service from the Services MSC just like all other
services:
Start Menu -> Control Panel -> Administrative Tools -> Services
You you can describe and replicate the problem, please file a ticket.
When you download the MGP package with IE, it guesses that it is indeed
a Zip file, and renames it.
You must take the entire zip file, and give it extension "mgp". Windows
Explorer sometimes hides the extensions of files per default, so watch
out for that.
When you have the MGP package, place the single file into the packages
directory, and it will appear in the Site Administrator.
Regards, Kenneth, GEOGRAF A/S
Bob W skrev:
> It appears Christy’s idea about MapGuide service running was the problem in
> this case.  I don’t know how mgserver.exe is being started, but I see it
> running where it wasn’t before.  (I have a useful program free program,
> Process Explore, which shows the processes that are running.)  Is there a
> procedure to start and stop mgserver?
> With MapGuide running I can login to Site Administer.
> Should I still open a trac ticket?
> This solution has brought me to the next problem: loading the Sheboygan.mpg
> package.  I’ve downloaded Sheboygan.mpg, extracted the files and copied them
> into the C:\Program Files\MapGuideOpenSource\Server\Packages directory.  I
> can see the file in the directory via Explorer.  MapGuide Site Administrator
> – Manage Packages – Load Package displays a “No packages found.“ message,
> and no package names appear in the Configure Packages directory table.
> Suggested solutions would be appreciated.
> Bob W wrote:
>> When I get to the 4th step in the Getting Started instructions the
>> MapGuide
>> Site Administrator Login wont accept the default user id Administrator
>> and password admin.  I get an Authentication failed. Please enter a
>> valid
>> username and password. message.
>> Ive removed and reinstalled the application, but the problem persists.
>> Does anyone have a suggestion about how to get around this problem?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080328/3e1dcad0/attachment.html
