SV: [mapguide-users] Grey image after some time in MGOS 2.0
Trond A. Tunheim
trond.tunheim at cellvision.com
Fri Mar 28 16:06:18 EDT 2008
Hi
There is no raster layers in this composition, only sdf vector layers. We had the same problem with MG 1.1.
/Trond Tunheim
Fra: Maksim Sestic <max at geoinova.com>
Sendt: 28. mars 2008 16:28
Til: mapguide-users at lists.osgeo.org <mapguide-users at lists.osgeo.org>
Emne: Re: [mapguide-users] Grey image after some time in MGOS 2.0
This is a common problem with Autodesk MapGuide Enteprise 2008 and Autodesk
Raster provider. Happens most often if you have several layers within base
layer group. During base layer tiling operation it happens that some tiles
simply get "skipped", and stay that way (cached as "empty" tile) even after
MapGuide service gets restarted. I hope Autodesk will get this fixed in 2009
version.
Regards,
Maksim Sestic
NorTrond wrote:
> Hi,
> We have experienced a problem with the MGOS 2.0 installation. After some
> time with moderate load it just returns grey images until the "Mapguide
> Server v2.0" service is restarted. We are using the WebApi with the
> GETMAPIMAGE mapagent operation.
> A quick look in the Error.log file reveals some details about the problem
> <2008-03-27T10:54:37>
> Anonymous
> Error: Failed to stylize layer: landlayer
> An exception occurred in FDO component.
> SDF connect failed. File does not exist or cannot be opened in
> specified access mode.
> StackTrace:
> - MgMappingUtil.StylizeLayers line 776 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
> SDF connect failed. File does not exist or cannot be opened in specified
> access mode.
> After restarting the Mapguide server service everything works fine for a
> while.
> We are using a web loadtester to reproduce the problem. The problem occurs
> with moderate load ( 2 users) continuously requesting maps for a set of
> areas. After about 2 hours the mapguide server ends up in the "gray
> state".
> Does anyone have any ideas about this problem ?
> Br
> Trond Tunheim, CellVision AS
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Grey-image-after-some-time-in-MGOS-2.0-tp16350277s16610p16351163.html
