SV: [mapguide-users] Grey image after some time in MGOS 2.0
    Kenneth, GEOGRAF A/S
    ks at geograf.dk
    Sat Mar 29 12:09:23 EDT 2008
I have seen this as well.
It happens less frequently with SDF than with OGR layers.
I have not yet had a reproduceable way of making the error appear.
Could you create a trac ticket, and possible enter descriptions for
setting up your "load test"?
http://trac.osgeo.org/mapguide/
Regards, Kenneth, GEOGRAF A/S
Trond A. Tunheim skrev:
> Hi
> There is no raster layers in this composition, only sdf vector layers. We had the same problem with MG 1.1.
> /Trond Tunheim
> ________________________________
> Fra: Maksim Sestic <max at geoinova.com>
> Sendt: 28. mars 2008 16:28
> Til: mapguide-users at lists.osgeo.org <mapguide-users at lists.osgeo.org>
> Emne: Re: [mapguide-users] Grey image after some time in MGOS 2.0
> This is a common problem with Autodesk MapGuide Enteprise 2008 and Autodesk
> Raster provider. Happens most often if you have several layers within base
> layer group. During base layer tiling operation it happens that some tiles
> simply get "skipped", and stay that way (cached as "empty" tile) even after
> MapGuide service gets restarted. I hope Autodesk will get this fixed in 2009
> version.
> Regards,
> Maksim Sestic
> NorTrond wrote:
>> Hi,
>> We have experienced a problem with the MGOS 2.0 installation. After some
>> time with moderate load it just returns grey images until the "Mapguide
>> Server v2.0" service is restarted. We are using the WebApi with the
>> GETMAPIMAGE mapagent operation.
>> A quick look in the Error.log file reveals some details about the problem
>> <2008-03-27T10:54:37>
>> Anonymous
>>  Error: Failed to stylize layer: landlayer
>>         An exception occurred in FDO component.
>>         SDF connect failed. File does not exist or cannot be opened in
>> specified access mode.
>>  StackTrace:
>>   - MgMappingUtil.StylizeLayers line 776 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
>> SDF connect failed. File does not exist or cannot be opened in specified
>> access mode.
>> After restarting the Mapguide server service everything works fine for a
>> while.
>> We are using a web loadtester to reproduce the problem. The problem occurs
>> with moderate load ( 2 users) continuously requesting maps for a set of
>> areas. After about 2 hours the mapguide server ends up in the "gray
>> state".
>> Does anyone have any ideas about this problem ?
>> Br
>> Trond Tunheim, CellVision AS
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Grey-image-after-some-time-in-MGOS-2.0-tp16350277s16610p16351163.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080329/4215681a/attachment.html
