[mapguide-users] Ajax Viewer zoom control and digitizing......
BruceWeston ross at ime.co.uk
Mon Mar 31 04:37:27 EDT 2008
I've just had a look at this Andrea and I notice the same issue. The user is
able to use the scroll wheel to zoom when in the middle of polygon
digitising.
Perhaps there is a way of disabling GoToView when in digitizing mode. Anyone
clever enough to intercept it?
andrea tiveron - metodi srl wrote:
> Hi Ross,
> I have the same problem
> but I have another problem in ajax viewer even more serious
> for example with an polygon
> if you are digitizing and between one point and another you change view
> with
> zoom or unzoom the markup  dimensions don't change
> can someone confirm me the same situation?
> andrea
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BruceWeston
> Sent: Thursday, March 27, 2008 5:27 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Ajax Viewer zoom control and digitizing......
> Hello folks,
> I have a bit of a problem when I'm digitizing a point using the ajax
> viewer.
> Here's why; if you are in digitizePoint mode and you click on the
> left/right/up/down pan controls or on the zoom bar, then the ajax viewer
> seems to see that as both a pan (or zoom) AND a digitize point.
> Has anyone been able to change the ajaxmappane.templ file so that this
> situation does not occur?
> I've had a search in the messages, but can't seem to see anything that
> helps
> me, but if you have posted something before, please be kind enough to
> point
> me in the right direction.
> Thanks in advance,
> Ross
> http://www.nabble.com/Ajax-Viewer-zoom-control-and-digitizing......-tp163272
> 04s16610p16327204.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Ajax-Viewer-zoom-control-and-digitizing......-tp16327204s16610p16393463.html
