[mapguide-users] Ajax Viewer zoom control and digitizing......
andrea tiveron - metodi srl andrea.tiveron at e-metodi.it
Fri Mar 28 10:08:09 EDT 2008
Hi Ross,
I have the same problem
but I have another problem in ajax viewer even more serious
for example with an polygon
if you are digitizing and between one point and another you change view with
zoom or unzoom the markup  dimensions don't change
can someone confirm me the same situation?
andrea
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of BruceWeston
Sent: Thursday, March 27, 2008 5:27 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Ajax Viewer zoom control and digitizing......
Hello folks,
I have a bit of a problem when I'm digitizing a point using the ajax viewer.
Here's why; if you are in digitizePoint mode and you click on the
left/right/up/down pan controls or on the zoom bar, then the ajax viewer
seems to see that as both a pan (or zoom) AND a digitize point.
Has anyone been able to change the ajaxmappane.templ file so that this
situation does not occur?
I've had a search in the messages, but can't seem to see anything that helps
me, but if you have posted something before, please be kind enough to point
me in the right direction.
Thanks in advance,
Ross
View this message in context:
http://www.nabble.com/Ajax-Viewer-zoom-control-and-digitizing......-tp163272
04s16610p16327204.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
