[mapguide-users] MGOS 2.0.0 Beta 2 loadfile error
Jim O'Leary jo at pat.ca
Sat May 3 23:08:19 EDT 2008
No, I have not solved it, nor heard word from anyone else who has solved it.
GordonL wrote:
> Hi Jim,
> Did you ever solve this one.  I am having this trouble on one server and
> getting the same response.  I comment out that load for that file in the
> CONF and it errors on the next MG dll....
> thanks
> gordon
> Jim O'Leary wrote:
>> I have installed MapGuide Open Source 2.0.0 Beta 2 on Windows Server
>> 2003. We also have MGE 2008 running on this machine.
>> The MGOS web server does not start. When I manually try to start it, it
>> says:
>> httpd.exe: Syntax error on line 126 of C:/Program
>> Files/MapGuideOpenSource2.0/We
>> bServerExtensions/Apache2/conf/httpd.conf: Cannot load
>> ../Php/MgHttpHandler.dll
>> into server: The specified procedure could not be found.
>> It is this line that causes the failure:
>> LoadFile ../Php/MgHttpHandler.dll
>> However, the MgHttpHandler.dll is there. The other DLLs appear to load.
>> I note a difference in the permissions that the user has for the MGOS
>> MgHttpHandler.dll and the Autodesk\MapGuideEnterprise2008
>> MgHttpHandler.dll. The former has only read and execute, the latter has
>> full control. However, when I manually add full control to the user for
>> the former, it does not fix the problem.
>> Any suggestions?
>> Thanks
Jim O’Leary Bachelor of Technology
Technical Consultant
Pacific Alliance Technologies
TEL 604.676.6000 EXT 110 TOL 877.691.9171
FAX 604.682.0962
WEB  http://www.pat.ca/ www.pat.ca
 “A Member
of StarDyne Technologies”
   http://www.stardynetech.com/ www.stardynetech.com
The information contained
in this message may be privileged and confidential and protected from
disclosure. If the reader of this message is not the intended recipient, or
an
employee or agent responsible for delivering this message to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this message is strictly prohibited. If you have received this
message in error, please notify us immediately by replying to this message
and
deleting it from your system without making a copy.  Internet
communications cannot be guaranteed to be secure or error-free as
information
could be intercepted, corrupted, lost, arrive late or contain viruses.
We
are not liable for the timely, proper or complete transmission of the
information contained in such communications.  We are also not liable
for
the loss of confidentiality of information contained in such communications.
View this message in context: http://www.nabble.com/MGOS-2.0.0-Beta-2-loadfile-error-tp14373978p17042293.html
