[mapguide-users] MGOS 2.0.0 Beta 2 loadfile error
GordonL
gordon.luckett at arrowgeomatics.com
Sat May 3 15:36:38 EDT 2008
Hi Jim,
Did you ever solve this one. I am having this trouble on one server and
getting the same response. I comment out that load for that file in the
CONF and it errors on the next MG dll....
thanks
gordon
Jim O'Leary wrote:
> I have installed MapGuide Open Source 2.0.0 Beta 2 on Windows Server 2003.
> We also have MGE 2008 running on this machine.
> The MGOS web server does not start. When I manually try to start it, it
> says:
> httpd.exe: Syntax error on line 126 of C:/Program
> Files/MapGuideOpenSource2.0/We
> bServerExtensions/Apache2/conf/httpd.conf: Cannot load
> ../Php/MgHttpHandler.dll
> into server: The specified procedure could not be found.
> It is this line that causes the failure:
> LoadFile ../Php/MgHttpHandler.dll
> However, the MgHttpHandler.dll is there. The other DLLs appear to load.
> I note a difference in the permissions that the user has for the MGOS
> MgHttpHandler.dll and the Autodesk\MapGuideEnterprise2008
> MgHttpHandler.dll. The former has only read and execute, the latter has
> full control. However, when I manually add full control to the user for
> the former, it does not fix the problem.
> Any suggestions?
> Thanks
View this message in context: http://www.nabble.com/MGOS-2.0.0-Beta-2-loadfile-error-tp14373978p17037586.html
