[mapguide-users] Re: getting layerdefinition
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon May 5 16:03:55 EDT 2008
So you have the resourceId, but need the layerdefinition xml?
Look at http://localhost/mapguide/mapagent/index.html
Click "Resource", then "GetResourceContent".
Fill in the field "Resource ID" and click submit.
You can read the URL of the resulting page:
http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2FTest%2FSources%2FWorld.FeatureSource&FORMAT=text%2Fxml
If you have a sessionID, you can append it as a parameter like:
&SESSION=...sessionid...
That will prevent it from asking about a username/password.
Alternatively add "&USERNAME=Anonymous&PASSWORD="
Regards, Kenneth, GEOGRAF A/S
alucas at srtec.com skrev:
> Hi kenneth,
> I need the layer definition for a layer.
> Kenneth, GEOGRAF A/S wrote:
>> What do you have to query with?
>> The map definition?
>> The runtime map?
>> The layer guid?
>> The layer name?
>> The layer xml?
>> alucas skrev:
>>> Hello,
>>> I know this is a strange question, but it's possible to get the resource
>>> id
>>> from a layer through mapagent? I need to get this information without
>>> using
>>> the server API if it is possible.
>>> For example: For the parcel's layer, I need to get
>>> Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition
>>> Thanks in advance
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Quoted from:
> http://www.nabble.com/getting-layerdefinition-tp17067340p17069516.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080505/95686e2f/attachment.html
