[mapguide-users] Re: getting layerdefinition
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon May 5 16:24:17 EDT 2008
Then it is difficult.
There are two ways.
1) Get the resourceID for the MapDefinition (I can't remember if it is
avalible in the viewer directly, but it should be)
Then get the MapDefinition like below, and search through the layers in
the map Xml.
This assumes that the current map has not been modified.
2) Download and parse the binary runtime layers resource tag. (Very
difficult, but is the most correct way).
If you have access to .Net on either the client or server, you can use
my .Net API to do this:
http://code.google.com/p/mapstudioos/wiki/HowToUseMapGuideAPI
Regards, Kenneth, GEOGRAF A/S
alucas at srtec.com skrev:
> I have only the layer name via mapFrame.GetLayers() and I need to get the path to the layerdefinition resource id.
> Kenneth, GEOGRAF A/S wrote:
>> So you have the resourceId, but need the layerdefinition xml?
>> Look at http://localhost/mapguide/mapagent/index.html
>> Click "Resource", then "GetResourceContent".
>> Fill in the field "Resource ID" and click submit.
>> You can read the URL of the resulting page:
>> http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2FTest%2FSources%2FWorld.FeatureSource&FORMAT=text%2Fxml
>> If you have a sessionID, you can append it as a parameter like:
>> &SESSION=...sessionid...
>> That will prevent it from asking about a username/password.
>> Alternatively add "&USERNAME=Anonymous&PASSWORD="
>>> Hi kenneth,
>>> I need the layer definition for a layer.
>>>> What do you have to query with?
>>>> The map definition?
>>>> The runtime map?
>>>> The layer guid?
>>>> The layer name?
>>>> The layer xml?
>>>> alucas skrev:
>>>>> Hello,
>>>>> I know this is a strange question, but it's possible to get the
>>>>> resource
>>>>> id
>>>>> from a layer through mapagent? I need to get this information without
>>>>> using
>>>>> the server API if it is possible.
>>>>> For example: For the parcel's layer, I need to get
>>>>> Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition
>>>>> Thanks in advance
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Quoted from:
>>> http://www.nabble.com/getting-layerdefinition-tp17067340p17069516.html
> Quoted from:
> http://www.nabble.com/getting-layerdefinition-tp17067340p17069757.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080505/0d186092/attachment.html
