[mapguide-users] Strating the Viewer with a defined scale (ceter, scale) from a link
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue May 6 03:37:19 EDT 2008
I don't think that is possible, out of the box.
You will need a small server side script that opens the WebLayout from
the server repository, modifies the starting point, saves it as a temp
resource, and redirects the page to the viewer with the temporary layout.
Regards,Kenneth, GEOGRAF A/S
Ulrich Beutel skrev:
> Dear Listers!
> For strating MapGuide 6.5 with a special view on an object in the map, may be a building, you can use a hyperlink like http://my-server/Mapguide6.5/My-website/my-map.mwf?Lat=5602311&Lon=4560544&Scale=1000&Units=M&Ext=mwf. So, for example you can create a table may be with Excel , describing some objects and by using the link the browser opens the map showing the object, you selected in that table.
> Or if you are using an ESRI - viewer you have to put in for example http://My-Server/My-Map/viewer.htm?Box=4567353:5615176:4569770:5616473&Layers=00110
> Is it possible to create a similar link to start the AJAX - viewer with a spcial defined map view in MapGuide OpenSource? Using Autodesk MapGuide Studio I can define a special initial view by putting in the Lat and Lon of the wanted center and the wanted scale into the WebLayout. But this is not the way to to find a solution for my question.
> Best regards
> Ulrich Beutel
> Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte Informationen.
> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben,
> informieren Sie bitte sofort den Absender und vernichten Sie diese Mail.
> Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> Kein Zugang für elektronisch signierte sowie verschlüsselte elektronische Dokumente !
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
