[mapguide-users] MapGuide studio expired
Jackie C. Ng
jumpinjackie at gmail.com
Tue May 6 11:10:46 EDT 2008
MapGuide Studio does not hold your spatial data hostage. You should be able
to access through alternate means.
If you go to the mapagent test pages
(http://yourservername/mapguide/mapagent/index.html) and choose the
EnumerateResources method, does it return a list of resources in xml format?
- Jackie
Viva_Rose wrote:
> Hello,
> I've install the mapguide studio into my PC to load shp file into the web
> application. Unfortunely when the studio application expired, all the data
> layer that i used to generate into web are disappear. Wat should i do?
> I've try to run webstudio open source but the webstudio are not
> working.The page look this everytime i try to load any shp file (refer to
> attachment). Really hope someone can help me to solve this problem.
> http://www.nabble.com/file/p17078652/prob.bmp prob.bmp
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/MapGuide-studio-expired-tp17078652p17085267.html
