[mapguide-users] MapGuide studio expired
Zac Spitzer zac.spitzer at gmail.com
Tue May 6 11:16:08 EDT 2008
webstudio didn't quite get as much love as it needed...
try this alternative to studio which 'just' became a mapguide project
http://code.google.com/p/mapstudioos
On Wed, May 7, 2008 at 1:10 AM, Jackie C. Ng <jumpinjackie at gmail.com> wrote:
>  MapGuide Studio does not hold your spatial data hostage. You should be able
>  to access through alternate means.
>  If you go to the mapagent test pages
>  (http://yourservername/mapguide/mapagent/index.html) and choose the
>  EnumerateResources method, does it return a list of resources in xml format?
>  - Jackie
>  Viva_Rose wrote:
>  > Hello,
>  > I've install the mapguide studio into my PC to load shp file into the web
>  > application. Unfortunely when the studio application expired, all the data
>  > layer that i used to generate into web are disappear. Wat should i do?
>  > I've try to run webstudio open source but the webstudio are not
>  > working.The page look this everytime i try to load any shp file (refer to
>  > attachment). Really hope someone can help me to solve this problem.
>  >  http://www.nabble.com/file/p17078652/prob.bmp prob.bmp
>  http://themapguyde.blogspot.com
>  http://www.linkedin.com/in/jackieng
>  View this message in context: http://www.nabble.com/MapGuide-studio-expired-tp17078652p17085267.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>  _______________________________________________
>  mapguide-users mailing list
>  mapguide-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
