[mapguide-users] Fusion - Tooltips
Jason Birch
Jason.Birch at nanaimo.ca
Tue May 6 16:44:07 EDT 2008
I've put a ticket into the Fusion trac about this:
http://trac.osgeo.org/fusion/ticket/56
Jason
Subject: RE: [mapguide-users] Fusion - Tooltips
Have you had a chance to test this with the latest Fusion build (1.4)?
It's working for me on a site that has .Net extensions installed as long
as I have the layer marked as selectable (which shouldn't be necessary,
but I don't think that Fusion is using the LAYERATTRIBUTEFILTER=4
bitmap).
Are you using the IIS and the .NET web extensions? If so, I have seen
the same problem and filed a ticket here:
http://trac.osgeo.org/mapguide/ticket/463
Tooltips and flexible layouts work fine for me with my PHP / Apache
installs, however.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080506/891e4437/attachment.html
