AW: [SPAM] - SV: [mapguide-users] Strating the Viewer with a defined
scale (ceter,
scale) from a link - E-Mail-Adresse wurde in Betreff-Zeile gefunden.
Ulrich Beutel
Ulrich.Beutel at lra-ana.de
Wed May 7 04:58:00 EDT 2008
Hi Måns,
thank you for this information. Now I integrate fusion and then I'll try it. Without fusion and only with AJAX it doesn't function.
Bets regards
Ulrich Beutel
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org]Im Auftrag von Måns
Beckman
Gesendet: Dienstag, 6. Mai 2008 09:34
An: MapGuide Users Mail List
Betreff: [SPAM] - SV: [mapguide-users] Strating the Viewer with a
defined scale (ceter,scale) from a link - E-Mail-Adresse wurde in
You can use a link in the form
http://localhost/mapguide/fusion/templates/mapguide/aqua/index.html?extent=-88.32,44.04,-88.31,44.05
It's basically the same way as you say they do it in ESRI.
Best regards
Måns
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Ulrich Beutel
Skickat: den 6 maj 2008 08:39
Till: mapguide-users at lists.osgeo.org
Ämne: [mapguide-users] Strating the Viewer with a defined scale (ceter,scale) from a link
Dear Listers!
For strating MapGuide 6.5 with a special view on an object in the map, may be a building, you can use a hyperlink like http://my-server/Mapguide6.5/My-website/my-map.mwf?Lat=5602311&Lon=4560544&Scale=1000&Units=M&Ext=mwf. So, for example you can create a table may be with Excel , describing some objects and by using the link the browser opens the map showing the object, you selected in that table.
Or if you are using an ESRI - viewer you have to put in for example http://My-Server/My-Map/viewer.htm?Box=4567353:5615176:4569770:5616473&Layers=00110
Is it possible to create a similar link to start the AJAX - viewer with a spcial defined map view in MapGuide OpenSource? Using Autodesk MapGuide Studio I can define a special initial view by putting in the Lat and Lon of the wanted center and the wanted scale into the WebLayout. But this is not the way to to find a solution for my question.
Best regards
Ulrich Beutel
Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte Informationen.
Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben,
informieren Sie bitte sofort den Absender und vernichten Sie diese Mail.
Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
Kein Zugang für elektronisch signierte sowie verschlüsselte elektronische Dokumente !
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
