[mapguide-users] How to produce .mgp format?
Jackie C. Ng jumpinjackie at gmail.com
Wed May 7 10:59:22 EDT 2008
Use the mapguide site administrator
(http://yourservername/mapguide/mapadmin/login.php)
Go to Manage Packages and under the Make Package section, enter the path of
the folder you want to package.
eg. If your data is in Library://Test/
Then the path can be either
- Library://Test/
- //Test
Submitting the form with any of these values will create an mgp package of
everything in that folder.
- Jackie
Viva_Rose wrote:
> Hi,
> I would like to know how do i produce .mgp such like 'sheboyan.mgp'? I
> oredi created all the layout and then how to make it in .mgp format?
> Need Help,
> Viva
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/How-to-produce-.mgp-format--tp17098907p17106208.html
