[mapguide-users] Mapguide Studio filter issue.
Robert Kovacs
rsksmiles at gmail.com
Wed May 7 11:02:48 EDT 2008
It is as simple as this:
BLD_CODE = 'KAD'
And there is nothing in the error.log
The change below refers to 2.1 containing this fix. Is this available ?
thanks
2008/5/7 Zac Spitzer <zac.spitzer at gmail.com>:
> Mapguide currently renders the whole layer when a filter fails, there
> has been a recent fix on the trunk
> which changes this behavior. http://trac.osgeo.org/mapguide/ticket/289
> Mg 2.0 should log an error i believe to error.log when this fails.
> http://trac.osgeo.org/mapguide/ticket/254
> I have seen the same issue with King.Oracle but not from memory with
> mg 2.0 and fdo 3.3.0
> what does your filter sql look like?
> z
> On Thu, May 8, 2008 at 12:03 AM, Robert Kovacs <rsksmiles at gmail.com>
> wrote:
> > Hi,
> > I am using the MG Server open source version 2.0 with oracle 9.2.xx for
> the
> > database.
> > I have mapguide studio 2008 and have tried to set a filter using the
> wizard
> > filter builder and when I view the result I see that the data has not
> been
> > filtered at all. Could this be an issue with fdo king? When I was
> trialing
> > the enterprise mg server 2008 the filter worked fine but that used a
> > different oacle fdo driver.
> > Help gratefully received!!
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080507/c7885901/attachment.html
