[mapguide-users] Fusion - Tooltips
Mike Adair
madair at dmsolutions.ca
Wed May 7 11:33:57 EDT 2008
Sorry, I spoke too soon about DomNode, I missed the instance of it used
in MapTips. widget. I will include a fix removing that reference in the
commit for this issue.
Mike
Mike Adair wrote:
> Thanks Jason, I've tested against trunk and it works well.
> About the DomNode issue that you mentioned, yes this changed for
> http://trac.osgeo.org/fusion/ticket/16 to get all of the methods into
> the Fusion namespace. For applications that depend on DomNode, you can
> either:
> - change your application logic slightly to get whatever XML was being
> parsed as JSON with Fusion.getXmlAsJson()
> - or just include lib/utils.js in your app index.html. Since DomNode
> is not needed anymore, utils.js doesn't get loaded automatically as
> part of Fusion initialization any more.
> Mike
> Jason Birch wrote:
>> I’ve put a ticket into the Fusion trac about this:
>> http://trac.osgeo.org/fusion/ticket/56
>> Jason
>> *From:* Jason Birch
>> *Subject:* RE: [mapguide-users] Fusion - Tooltips
>> Have you had a chance to test this with the latest Fusion build (1.4)?
>> It’s working for me on a site that has .Net extensions installed as
>> long as I have the layer marked as selectable (which shouldn’t be
>> necessary, but I don’t think that Fusion is using the
>> LAYERATTRIBUTEFILTER=4 bitmap).
>> *From:* Andy Morsell
>> Are you using the IIS and the .NET web extensions? If so, I have seen
>> the same problem and filed a ticket here:
>> http://trac.osgeo.org/mapguide/ticket/463
>> Tooltips and flexible layouts work fine for me with my PHP / Apache
>> installs, however.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
