[mapguide-users] query question
David Nuell nuell at nicholsenvironmental.com
Wed May 7 15:58:05 EDT 2008
Thanks for the suggestion Andrew.  I appreciate the response.  I had a look
at the search command, and like you say - it is pretty limited.  I'm hoping
to get the 'robustness' of the query to work so that users can query
anything they want.
Any other suggestions?
andrew.demerchant wrote:
> Not sure that I can be of help with this specifically, but I do know
> that there is a built-in search command, and it works fine. Maybe it
> would do the trick? It may be too limited for you though - only one
> field can be searched...
> Andrew
> David Nuell wrote:
>> Hi all - I am going to repost this in hopes that someone can help.
>> Cheers!
>> (see original post)
>> David Nuell wrote:
>>> Hi Listers -
>>> I am having some troubles with a query function and I hope that someone
>>> out there can help.
>>> - I have a map built via MapGuide Studio
>>> - I have created a new command called 'Query'
>>> - I have enter the exact same information into the settings of the query
>>> command as in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
>>> - save my web layout and open it in an AJAX viewer (and/or DWF viewer)
>>> - select the query command and it opens in the side window (right pane)
>>> - I can select a layer that is in my layers list along with everything
>>> else to query the data including the output property.
>>> As soon as I hit execute, nothing shows up in the results panel...
>>> What am I missing? Any ideas?
>>> Thanks (again).
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/query-question-tp16993307p17113384.html
