[mapguide-users] query question
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed May 7 15:32:05 EDT 2008
Not sure that I can be of help with this specifically, but I do know
that there is a built-in search command, and it works fine. Maybe it
would do the trick? It may be too limited for you though - only one
field can be searched...
Andrew
David Nuell wrote:
> Hi all - I am going to repost this in hopes that someone can help. Cheers!
> (see original post)
> David Nuell wrote:
>> Hi Listers -
>> I am having some troubles with a query function and I hope that someone
>> out there can help.
>> - I have a map built via MapGuide Studio
>> - I have created a new command called 'Query'
>> - I have enter the exact same information into the settings of the query
>> command as in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
>> - save my web layout and open it in an AJAX viewer (and/or DWF viewer)
>> - select the query command and it opens in the side window (right pane)
>> - I can select a layer that is in my layers list along with everything
>> else to query the data including the output property.
>> As soon as I hit execute, nothing shows up in the results panel...
>> What am I missing? Any ideas?
>> Thanks (again).
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
