[mapguide-users] query question
David Nuell
nuell at nicholsenvironmental.com
Wed May 7 15:25:07 EDT 2008
Hi all - I am going to repost this in hopes that someone can help. Cheers!
(see original post)
David Nuell wrote:
> Hi Listers -
> I am having some troubles with a query function and I hope that someone
> out there can help.
> - I have a map built via MapGuide Studio
> - I have created a new command called 'Query'
> - I have enter the exact same information into the settings of the query
> command as in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
> - save my web layout and open it in an AJAX viewer (and/or DWF viewer)
> - select the query command and it opens in the side window (right pane)
> - I can select a layer that is in my layers list along with everything
> else to query the data including the output property.
> As soon as I hit execute, nothing shows up in the results panel...
> What am I missing? Any ideas?
> Thanks (again).
View this message in context: http://www.nabble.com/query-question-tp16993307p17112413.html
