[mapguide-users] query question
David Nuell
nuell at nicholsenvironmental.com
Thu May 1 11:54:24 EDT 2008
Hi Listers -
I am having some troubles with a query function and I hope that someone out
there can help.
- have a map built via MapGuide Studio
- have created a new command called 'Query'
- enter the exact same information into the settings of the query command as
in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
- save my web layout and open it in an AJAX viewer (and/or DWF viewer)
- select the query command and it opens in the side window (right pane)
- I can select a layer that is in my layers list along with everything else
to query the data including the output property.
As soon as I hit execute, nothing shows up. I have the Sheboygan data
installed and I tried to execute a query there too... but same result.
Nothing shows up in the results panel.
What am I missing? I suppose it has something to do with the install since
the sheboygan query does not work either. Any ideas?
Thanks (again).
View this message in context: http://www.nabble.com/query-question-tp16993307p16993307.html
