[mapguide-users] MapGuide Selection and UniqueID Determination
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu May 8 09:03:34 EDT 2008
It should be enough to call SetSelectionXml.
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
> I have a quick question about selection as well...If I have the
> selection XML can I just call the Javascript Function setSelection, or
> do I have to do the code in the code behind for it to work? Basically I
> have tried itand it does display that a selection has been made in the
> panel and the status bar, but the map is not updated, even after a
> refresh...
> -Thanks
> Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
> GEOGRAF A/S
> Sent: Thursday, May 08, 2008 2:56 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MapGuide Selection and UniqueID
> Determination
> To be able to select items the layer must be selectable (set in the
> MapDefinition).
> Secondly, the FeatureSource must have at least one identity column.
> If not, all features on the layer are selected.
> Crispin @ 1Spatial skrev:
>> Hi,
>> Can someone explain how the magic of MapGuide selection works...
>> Of particular interest to me is a particular ArcSDE dataset that
> appears
>> fine in MapGuide but (despite correct settings in Studio) has a class
> of
>> points which when mapped as a layer do not 'select' in the map.
>> Using a seperate direct FDO connection I can see the class has no
>> columns/proprttydefinitions that are "IsAutogenerated()" - is this a
>> requirement for a layer to be selectable or is there another criteria?
>> Tooltips appear OK.
>>  Crispin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080508/19d80533/attachment.html
